10.5.2 + SpamSieve = no go?
Hey folks,
I just got my new MacPro set up yesterday. First time on Leopard. I immediately updated to 10.5.2.
I’ve installed SS, but every time I launch Mail it tells me SS has been disabled.
Anything I’m missing or is an update in the works?
Thanks!
It should work if you choose “Install Apple Mail Plug-In” from the SpamSieve menu.
I would have sworn I did that. Worked this time.
Perhaps I just hadn’t quit Mail prior to the first attempt at install.
Thanks Michael!
