A few more questions...
Hi-I am liking EagleFiler. I am still using the free trial but I have a couple more questions…
  1. Is there a way to have tabs for all the libraries?
Ha! Looks like I have just that one question… Thanks!!
Yes, for example there are way to control whether a new window is opened as a tab. Or if you already have multiple libraries open in separate windows, you can use the Window ‣ Merge All Windows command to turn them into tabs.
