If it’s been discussed/explained somewhere I can’t find it. Is it possible to have a tag automatically assigned to everything that is put into a certain folder?
Not directly, however:
- You could drag files onto a tag in EagleFiler’s source list, and it will behave like a folder in certain ways.
- You could setup a smart folder to do this. The conditions aren’t important, but you could set the actions to move the file into a certain folder and add certain tags. Then drag the files onto the smart folder to move/tag at the same time.
Thanks. I didn’t know anything about the Actions feature. Your #2 is working for me.
