Aliases in Stationery Folder
Hi,
I made aliases in my stationery folder to RTF and RTFD files. Unfortunately, EagleFiler (1.4.4) does not seem to deal with them as I expected it would. When I created a new record, the record contained an alias rather than a document. When I edited the record in an external editor (TextEdit), I edited the aliased file rather than a copy.
I am not sure what the correct general behaviour for aliases should be, but at the very least, I think EagleFiler should follow aliases in the stationery folder.
Clearly, this is not an urgent problem, since there is an obvious work around.
Regards,
Alan
Agreed. Thanks for the report.
EagleFiler 1.4.5 follows aliases in the Stationery folder.
