AppleScript and Tags
Hello,
I’m trying to use the Reload Web Pages script on a few records only (vs all of them). I tagged these records in my library with a tag named “autorefresh” and attempted to retrieve them using the following script:
tell application "EagleFiler"
	set _tagname to "autorefresh"
	set _records to displayed records of browser window 1
	set _tags to tags of library document 1
	-- looking for "autorefresh" tag
	set found to false
	repeat with _tag in _tags
		if _tag's name is _tagname then
			set found to true
			exit repeat
		end if
	end repeat
	if found then
		-- looking for the records with this tag
			if the assigned tags of _record contains {_tag} then
				beep
				-- reloadWebPage(_record)
			end if
		end repeat
	end if
end tell
At least one record with the “autorefresh” tag exists, but no beep is produced (note: my Mac’s audio output works fine :).
My questions:
  1. where’s my mistake? (besides being a newbie in Applescript)
  2. is there a better way to do it?
Thanks in advance!
Arsene
I’m not entirely sure why your way didn’t work. I think it’s something to do with _tag being a specifier (the i-th tag of _tags) rather than an actual tag. When I write it like this, it seems to work:
    try
        set _tag to tag _tagname of library document 1
    on error
        return
    end try
            beep
        end if
    end repeat
end tell
Periodical script and “search” in Applescript
It works indeed! Thanks for such a quick reply!
Two more questions:
My first idea was to trigger the script every now and then using Hazel on a dummy folder. Is there something less intricated to run periodically a script?
Would it be interesting to add a “search” command to the EagleFiler dictionary?
My problem would have been solved in a breeze:
	tell browser window 1
		search with query {"autorefresh"} in field {tags}
		repeat with _record in selected records of browser window 1
			my reloadWebPages(_record)
		end repeat
	end tell
end tell
Thanks again!
Arsene
You could use cron or iCal, which ship with Mac OS X. There are also various utilities such as iDo Script Scheduler and Script Timer.
Yes, that’s something I’m working on.
EagleFiler 1.4.5 adds the “assigned tag names” property, which should make it easier to write this type of script.
