I downloaded EagleFiler 1.2.6 earlier today and have been experimenting with it. When attempting to capture from Word (using the capture key), I get the error shown in the attached JPEG. How to I fix this?
I haven’t seen this problem before. .Which version of Word do you have?
You could try quitting EagleFiler and putting the attached script file in the folder:
/Users/<username>/Library/Application Support/EagleFiler/Capture Scripts/
Word X for Mac, Service Release 1
No folder by that name lives there.
Aha. I don’t have Word v.X handy to test this, but I suspect its AppleScript support isn’t compatible and the capturing will only work with Word 2004 or later.
You would need to create the “Capture Scripts” folder.
That must be the problem. I created a Capture Scripts folder and placed the script you sent in it. Now I get a different message (attached).
