Hi Micheal,
thx for Eaglefiler! I like it!
Do you plan to set up automated import actions?
I think the basic work is done? - it would be greate to get the hotfolder-Action-tab for the normal import!
Hi Micheal,
Sorry, but I’m not quite sure what you are asking here. EagleFiler will automatically import files added to the To Import or Files folder. You can hold down the Option key during a manual import to get the Options window. This can let you set the folder or tags of the new records, and it will remember the options you used the last time.
I would like to have a possibility to add automated tags in depencie of the filename or parts of it.
OK, thanks for explaining. I’m not sure whether I will add that sort of feature to EagleFiler, but I’ll keep it in mind. For now, there’s a great app called Hazel that can do this sort of thing. You might want to use it in combination with EagleFiler.
