Building from console/ssh
Hi,
We recently setup our environment to use an automated build server. This machine runs builds on other machines using ssh. Our build step hangs when creating the dmg. It shows an error on the desktop saying that there was an error with getting the licese file. I have attached a screenshot. Is there a workaround for this?
Thanks
Chris
My guess is that this error is not related to using ssh. Have you tried making the image while sitting at your build server?
Building at the desktop works with no problems. I’m guessing that there’s something missing in the environment when running from ssh. Maybe there is something missing in the environment when running from ssh and DropDmg can’t find/talk to the .plist?
Thanks
Chris
Which command are you executing from ssh? Are you using the “dropdmg” command-line tool?
