On an early Intel Imac running OS 10.8.
Carbon Copy gave an error that it couldn’t back up because a file with the same name but of a different type already exists. I frankly do not know what this means, but the log indicates that the problem is a SpamSieve file(s). The entire log is too long for one post, but this gives the idea:
08:00:50 Launched Carbon Copy Cloner [3.2.1] on Version 10.5.8 (Build 9L30)
08:59:43 The system is about to sleep. No tasks are running, so I’m not dissenting.
08:59:43 The system is going to sleep, there’s nothing CCC can do to prevent it.
09:29:08 Wake from sleep
09:29:18 Boot Backup: Scheduling for Friday, September 25, 2009 10:00 AM
==================== Carbon Copy Cloner (v. 3.2.1): 2009-09-25 10:00:00 -0700 ====================
Operating System: Version 10.5.8 (Build 9L30)
Hardware:
hw.machine: i386
hw.model: iMac4,1
hw.logicalcpu: 2
hw.physmem: 2147483648
vm.loadavg: { 0.69 0.25 0.09 }
Task: Boot Backup
Source: Macintosh HD (/dev/disk0s2, 2B464BC0-6F15-32BD-889F-B2D2665B2631)
Mount point: /
Filesystem: hfs
Capacity: 221.32 GB
Used: 102.67 GB
Available: 118.65 GB
Mac OS X version: 10.5.8
Target: 250GB ME Boot Clone (/Volumes/250GB ME Boot Clone/ [/dev/disk2s3, 36A61F29-F656-33F7-9E8F-110CBCE78042])
Mount point: /Volumes/250GB ME Boot Clone
Filesystem: hfs
Capacity: 233.64 GB
Used: 132.90 GB
Available: 100.74 GB
Cloning method: Incremental backup of selected items
Delete: No
Protect: No
Archive: No
Compress: No
10:00:00 The target volume has ownership enabled.
10:00:00 The target volume has Access Control Lists enabled.
10:00:00 Authenticating…
10:00:00 Initiating synchronization engine…
10:00:01 Building a list of items to be considered for backup
10:16:38 Preparing to copy, total items to consider: 1688950
10:16:38 Build time: 997.071
10:16:56 Comparing selected items on the source and target…
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/MJTAboutWindow.nib” on the target volume because an item with the same name
but a different type (regular file) already exists in that location.
You have instructed CCC to not delete items from the target that are not on the source,
so CCC cannot delete the offending item. Manually delete the item from the target, or
re-run CCC with the “Delete items from target that are not on source” option enabled.
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/MJTActivity.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/MJTActivityView.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/MJTProgressWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/MJTTextWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/Danish.lproj/MJTFindPanel.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/Danish.lproj/MJTRegistrationWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/Danish.lproj/MJTSoftwareUpdateWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/Dutch.lproj/MJTFindPanel.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/Dutch.lproj/MJTRegistrationWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/Dutch.lproj/MJTSoftwareUpdateWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/English.lproj/MJTFindPanel.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/English.lproj/MJTRegistrationWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/English.lproj/MJTSoftwareUpdateWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/French.lproj/MJTFindPanel.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/French.lproj/MJTRegistrationWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/French.lproj/MJTSoftwareUpdateWindow.nib” on the target volume because an item with the same name
10:18:19 CCC was unable to replace “Applications/SpamSieve.app/Contents/Frameworks/MJTApplication.framework/Versions/A/Resources/German.lproj/MJTFindPanel.nib” on the target volume because an item with the same name
