Is there a way to keep Spamsieve in sync between my Macbook, iMac, iPad and iPhone?
I find myself cleaning the spam folder repeatedly in each of this computers.
Please advice.
Un abrazo,
Robby!
Please advice.
Un abrazo,
Robby!
It’s not entirely clear to me what you mean by “in sync.” If you use IMAP, you can have a single Spam mailbox for all your computers. Then you only have to check it once, from whichever device is most convenient. If you have a Mac that will be on most of the time, it’s simplest to install a single copy of SpamSieve. You can optionally use the drone setup to train it from the other devices.
