Do I have to notarize my .dmg AND my .app when distributing?
I think I’m almost there, I installed notarytool.
When I submit my .dmg for notarization, do I have to wrap it in a .zip file, or submit the .dmg as it is (because .dmg is an archive file)?
When I submit my .app for notarization, I have to wrap it in a .zip:
ditto -c -k --keepParent "dist/My Application.app" dist/MyApplication.zip
xcrun notarytool submit dist/MyApplication.zip --keychain-profile "mykeychain_profile_just_created" --wait
Do those two command lines look ok?
You can submit the .dmg file directly.
Thanks… its my understanding that if I submit the .dmg it will automatically notarize the app inside the .dmg too.
Am I correct in thinking that?
Correct.
Yay, finally made it - thank you so much for your input, its been very helpful.
I’m a Windows guy so this has been a rabbit hole for me, but made it in the end.
I don’t suppose there is a way to get rid of this message is there? I think I’m stuck with it, not a big deal just wondering.
Yeah, I don’t think you can get rid of that. The fact that it says “Apple checked it…” indicates that the system does recognize the app as being notarized.
Is the ability to Notarize and Sign included in the $99 Apple Developer account fee ?
Yes, it’s included with the annual membership.
