DropDMG 3.6.7b3 Public Beta
Here’s a new beta version of DropDMG. The changes are:
  • DropDMG now double-checks the positions of invisible icons to make sure they don’t appear on top of your layout.
  • The Creating a DropDMG Quick Action instructions now explain how to use the Shortcuts app.
  • Made various fixes and updates to prevent Cocoa from logging warnings.
If you have not installed a beta version of DropDMG before, first click here to enter the beta key. Thereafter, you can just launch DropDMG or choose Software Update from the DropDMG menu to auto-install the beta. DropDMG will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
Will the beta work with a standard key or do I need to change it?
I think, I just had my answer, changing the key triggerd the beta download.
Cheers,
– Harald
