DropDMG 3.7.2b1 Public Beta
Here’s a new beta version of DropDMG. The changes are:
  • Work around a macOS bug that could cause license agreement names to be truncated in the outline view.
  • Worked around a bug in macOS 27 that could cause a crash when editing an Arabic license agreement.
  • Worked around a bug in macOS 27 that could cause text to be deleted when building a disk image with an Arabic license agreement.
  • Help links once again open in the system help viewer on recent versions of macOS.
  • The Help menu commands and the Quit menu command are now available when the trial period is over, rather than only making those commands available as buttons within the modal window.
  • Fixed a bug where DropDMG might incorrectly report that the window’s size didn’t match the layout when it was only off by a fraction of a pixel.
If you have not installed a beta version of DropDMG before, first click here to enter the beta key. Thereafter, you can just launch DropDMG or choose Software Update from the DropDMG menu to auto-install the beta. DropDMG will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
