Here’s a new beta version of DropDMG. The changes are:
- The disk image’s Finder window size is now optimized for display on the version of macOS where DropDMG is running. The most visible effect of this is that creating a disk image on a modern version of macOS will now show the entire background picture, rather than having some of the bottom scrolled out of view. If you would like to use a modern version of macOS to create a disk image optimized for macOS 10.15 or earlier, or vice-versa, you can specify that using
LayoutTitleBarHeightin the esoteric preferences. - Made various updates for Xcode 27 and macOS 27.
- Fixed a bug where creating a disk image with a layout could fail on macOS 10.13 or 10.14.
- Fixed a bug where replacing an old diagnostic report with a new one didn’t work.
- Updated the crash reporter layout.
If you have not installed a beta version of DropDMG before, first click here to enter the beta key. Thereafter, you can just launch DropDMG or choose Software Update from the DropDMG menu to auto-install the beta. DropDMG will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
Previously: Beta 1.
