EagleFiler 1.9.14b1 Public Beta
Here’s a new beta version of EagleFiler. The changes are:
  • Fixed a bug where some files imported from Evernote could have truncated names or tags.
  • Fixed a bug where importing from Evernote could fail if a note had multiple attachments with very long filenames that were similar.
  • Updated the How can I encrypt my files? section of the manual.
  • Fixed internal errors that could occur in the process of closing a library.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
