I don’t have a huge library, but suddenly it’s taking 5 seconds or so for Eaglefiler to engage once I move over to its window. I command-tab over to it and try to scroll down the library, using the mouse, and nothing happens for an irritatingly long time. What could be the problem?
Is there anything showing in EagleFiler’s Activity window?
Is there anything in the library’s “To Import” folder? If so, EagleFiler will ask the OS whether the files are in use (it doesn’t try to import files that are in use), and that might block things for a little while.
Interesting–there was indeed an open file in the “To Import” folder. I’ll report back if closing it doesn’t solve things.
That was totally it. Thanks.
