You can click this link (after installing EagleFiler) to join the public beta program and receive updates via the built-in Software Update… command. Click this link to stop receiving beta updates.
The beta release notes are available in the Software Update window and also in the Version History section of the manual (in the Help menu).
macOS 10.13 High Sierra Beta 1 is not yet supported; EagleFiler will launch, but it may encounter an error when trying to save changes to the library. This thread will be updated with more information as it becomes available.
We do not recommend using a macOS beta on your main Mac, as there may be bugs that we have not had time to, or cannot, work around. With that said, we do welcome bug reports so that we can investigate any bugs and report them to Apple or try to develop workarounds. Please submit any feedback or bug reports via e-mail, rather than posting here.
EagleFiler 1.8b3 adds preliminary support for macOS 10.13 Beta 2.
