Editing in another program
The manual says:
“Use the Update Checksum command if you have edited a file using another program; this tells EagleFiler that the file has changed because you modified it, not because it became damaged.”
Does this apply even if the editing is done using the “Open in …” menu command?
I understand the need to do this if I open the file with another application from the Finder, but I’m not sure about this if I opened it from within EF. Maybe EF updates the Checksum all by itself in this case.
If it is necessary to update manually every time, it would be nice to be able to set a shortcut for the command or put it in the Toolbar.
Ellen
Yes.
Noted, thanks.
With EagleFiler 1.3, you can add Update Checksum to the toolbar.
