I see that a Word document with EndNote macros doesn’t display properly in EagleFiler’s reader pane. However, if I double-click on the record, a Word document comes up that appears to be just fine. Is there anything I am doing wrong on the import that causes problems in the browse pane?
Example: where the first reference appears, the pane will have ADDINE EN.CITE <EndNote><Cite><Author>… for several lines.
No, the file is importing correctly. EagleFiler relies on Apple’s code to display Word documents, and it doesn’t support all the features. To display a Word document with perfect fidelity, you need to use Word itself.
