Recently I started receiving the following error when starting and closing EagleFiler:
Could not Save Library
An error occurred while saving
NSCocoaErrorDomain: 134030
While EagleFiler appears to open my library, the file is emtpy. I can open the same file on another computer running EagleFiler and all seems fine.
This is a nre problem and reinstalling and upgrading the application has made no difference.
Any advice would be appreciated, Thanks
When you say “the same file” do you mean that you copied your EagleFiler library to another Mac? Or that you have two Macs accessing the same network drive? Or…?
Thanks. It looks like there’s a problem reading the file from your drive. The file may be damaged, or there may be something wrong with the drive itself. You could try rebuilding your library, but if problems persist you may need to repair or replace the drive.
