Hi, I’m evaluating Eaglefiler and finding a lot of things I like. Nice work so far.
I found a problem when I tried to create a folder with a ‘/’ in the name. It creates the folder with only the text after the ‘/’. If you try and create a folder that ends with ‘//’ it will create a folder with the name ‘-1’.
Sorry about that. I’ve fixed the bug for the next version. It looks like you’ve turned off e-mail from the forum; contact me at eaglefiler@c-command.com and I’ll send you a pre-release build that includes the fix.
