I just noticed that several folders disappeared from Library/Records. It seems to be all the folders after the beginning letter of “M” (Mail folder).
Earlier this afternoon, I moved a file to a folder that is no longer listed. I looked at my backup drive and found the “Files” folder had all the missing folders (however, the backup is a week old). I lost files I saved the last couple of days.
I’ve quit and restarted EagleFiler (v. 1.4.5) without success. The folders are just gone. I was not doing any global cleanup or anything and have not even used Finder to view my EF folder where all the files reside.
Wait, I did get an ERROR dialog when starting up EF earlier today. I had sent the error to you. Was the starting up error the cause?
Strange indeed. Since the folders are stored separately from EagleFiler’s database entries for them, I can think of only two ways the above could happen:
The folders were accidentally moved to EagleFiler’s trash, and then the trash was emptied.
There was some sort of disk problem that affected both the folders and EagleFiler’s database file.
