I have an idea…
…why don’t I just read the extremely well written manual? And lo and behold it is all explained in there.
I suppose this might be a bug though as I have turned of Growl notifications in SpamSieve, but I still have to go turn them off in the Growl Prefs as well? That doesn’t sound right.
Thanks for the report. I just checked the code. Due to a typo, SpamSieve will currently send the Uncertain Spam notification to Growl even if Growl is turned off in SpamSieve’s preferences. I will fix this in the next release of SpamSieve.
Okay, I’m new to Spamsieve. Just downloaded it last night, and so far, I like it. If it keeps working this well, I’ll convert the trial version to paid in a few days.
But . . . I’m posting this here in hopes that the noise that Mac Mail has started making after I installed Spamsieve is the “growl” referenced here.
How can I turn it off?
Under Mail Preferences, I do not have New Mail Sound checked. I can’t use this program if it’s going to make sounds.
Growl refers to this. SpamSieve has a separate preference for playing a sound when good messages are received, and you can turn it off in the Notification section of its Preferences window.
