Hide already-imported files by extension
Many of my folders contain .skim notes (Skim’s PDF annotation files) or other files which I never want to see in EagleFiler, but don’t want to delete.
Could EagleFiler 2 apply the ignored-extensions list to records already in the library, hiding them without deleting the files?
Also, could EF store that list as a per-library setting, so we could have different settings for different libraries, and have such settings travel with the library to a new Mac?
P.S. I know about the UnscannedExtensions default, and that I could rebuild each library, but these fixes do not really do the job for me:
  1. The UnscannedExtensions it only stops new files from being imported; any .skim files that are already in the library stay visible. This keeps catching me out when I move to a new Mac: the default lives in the Mac’s preferences rather than in the library, so I forget to set it again, and by the time I notice, EagleFiler has already imported a fresh batch of .skim files.
  2. I know I could rebuild each library from scratch after setting the default, but this takes a long time (I have several libraries).
Thanks for the suggestions. Right now, rebuilding is the best way, but I realize that can be a burden. I’ll make a note to look into making this better. One issue is that I don’t want to throw away metadata that’s been added to the new ignored files. It’s possible that the user wants to keep it or even made a mistake in specifying the extensions. I’m trying to think of how best to handle this. Maybe such files should still be kept in the database but hidden from view, rather than not being in the database at all like with normal ignored files.
Thanks! Yes, I think remaining in the database (while not being displayed) would be best.
Since would allow people to switch back and forth being displaying something and not doing so; this happens to me periodically, as I sometimes need to one of those auxiliary file created by latex in compilation (e.g. an .aux or .bbl file) which I normally want to hide; now to access such files I need to eschew EF and “reveal in Finder” the appropriate folder to see that file (which works well enough, so it is not really a problem).
