Sorry if these questions are answered elsewhere – couldn’t find them, so
I just tried importing my entire Mac documents folder, which is a mess. EF crashed part way into the import. Not sure why, but I eliminated some “unusual” files in Docs, in case they were at fault.
In order to complete the import should start the process over, in a new library? Or is the proper approach just to try to add the whole Docs folder again, because EF will eliminate the duplicates?
Once I finish the import, can I rename the EF created directory to Documents, and Get rid of my original documents folder? Or will that cause problems?
