Importing text from Comments field from Together into EagleFiler 1.5
Hi,
Is there a way to import the text that resides in the Comments field from Together 2.3 records into the Notes field in Eaglefiler 1.5? These are Comments in the Together program, not Spotlight comments. I imported about 600 records from Together into Eaglefiler recently and for the most part it worked well. Tags were assigned as expected, but none of the Comments were transferred. Maybe this is just not possible?
Yes, this should work if you import via the capture key. However, it looks like Together changed its AppleScript dictionary, which broke EagleFiler’s importer. Please contact me via e-mail to test an updated version.
I’ve fixed this in EagleFiler 1.5.1.
