index voodoopad document
Will Eaglefiler be able to index and search .vpdoc files in the near future?
I thought the feature might already be supported because .vpdoc files are indexed through Spotlight. However, I have not had success. Thanks.
Probably not, unless VoodooPad’s Spotlight importer plug-in is modified to support that. I’ll look into whether EagleFiler can read the contents of the .vpdoc files directly.
The .vpdoc files are not indexed by Spotlight. Rather, VoodooPad can optionally write .vpspotlight files into the folder ~/Library/Caches/Metadata/VoodooPad, and Spotlight indexes those files.
