lost of eflibrary
Hi
As I am currently moving my datas on a new Hard Drive I just realized that it looks I lost my eflibrary file attached to the library and then it’s impossible for me to open anymore my library.
I there any chance I recover it ?
Thanks
Regards
BKantique
Easiest would be if you have a backup of it. However, everything in the .eflibrary can be regenerated from EagleFiler’s automatic XML backups.
Hi Michael
Thanks for this
Actually I found the way you told me by myself… and now all is on order I backup and reinitiated my libraries without any issue :slight_smile:
Best Regards
BKantique
