Lost Smart Folder Icons
Hello
Using EagleFiler 1.5.10 I now have a generic icon for all the Smart Folders I have set up.
Although updated both EF and Mac OS X in the last few days I am fairly sure I lost them with the OS X 10.7.4 update rather than with the EF 1.5.10 update.
Anyway, the key question is, does anyone have any thoughts as to how to get the icons back in EagleFiler?
Thanks
Graham
It’s due to a bug in Mac OS X 10.7.4. If you re-download EagleFiler 1.5.10 it contains a workaround.
Yes, that works. Everything is back to normail.
Thanks for the speedy response.
Graham
