Are you saying that you have two SpamSieve.mailbundle’s, one in each Bundles folder? I suggest deleting all the Disabled ones, just to clear things up.
Hi Michael, yes I have a Bundle in both locations… is this normal ? I have deleted the other Disabled folders etc… restarted… but still the same !
thanks
Norman
No, there should be only the:
/Users/<username>/Library/Mail/Bundles/SpamSieve.mailbundle
one.
Success ! Removed the Bundle in the /Library/Mail folder and it now loads properly… thanks for your help.
regards
Norman
