I am trying to work with tags in lieu of the smartfolders in other programs. It’s not the same, and EagleFiler’s procedures are slower if I get them) because I there is no opportunity to file and tag before copying a file into EagleFiler. Tags and folders cannot be tied to each other. They are separate filing systems. You can drag a file to a folder or tag - but not both at one time. Do I understand this correctly?
Trying to make tagging (especially multiple tags) more convenient, can folders and tags be tied together?
I also discovered that tags can be nested in the source pane. However, dragging a file to a nested tag only tags the file with the nested tag and not also the parent tag. I thought it might be useful to tag with both tags. It would make it easier and faster. What do you think?
Thank you again.
Regards,
Gene
