Notes panel
Have you considered implementing a pane, or panel, that appears directly in the bottom of the Preview pane, to display (and allow editing) of the Notes of an item if it should happen to have any? Something roughly similar, interface-wise, to the iTunes Ministore?
Yes, that’s a feature I’d like to add.
