Quick tag searches in EagleFiler 1.5
Hi,
I like Eaglefiler 1.5. I have one question regarding selecting two tags for a “quick tag search” that shows the records that have both of the selected tags. If I select the Library as the source and then hold down the command key before selecting each of the tags, I get the expected behavior: the records that have both tags. However, if I select one tag (without holding down the command key) and then decide to add a second tag (by now pressing the command key followed by selecting the second tag), I get no records found.
Is this the expected behavior? I thought that the two methods should yield the same result but maybe I am missing something.
You’re right; the two methods should be equivalent. This bug is fixed for the upcoming EagleFiler 1.5.1.
This is fixed in EagleFiler 1.5.1.
