scripted folders available?
Do you have a folder with script that can open EF automatically and file things into one EF library? I’d love to have a folder like that for each EF libarary in order to file without thinking… I don’t generally keep EF program open
You could try this one. However, I personally don’t think this is very convenient since it will cause EagleFiler to launch when you save the file. I’m working on a more integrated solution.
EagleFiler 1.2 adds a “To Import” folder to each library. From any application, you can save files or folders into the “To Import” folder that’s next to the “.eflibrary” file in the Finder. When the library is opened (and, periodically, while it’s open) EagleFiler checks this folder, imports any files that are in it, and then deletes them.
