Just an FR.
I needed to find something in EF and I hadn’t used it in a while, so I didn’t see the tags on the left. So I went to the search box to try to find it, but I discovered that it doesn’t search the tags.
I think it should.
Thanks
Just an FR.
I think it should.
Thanks
It does if you select Tags from the menu. It’s on my to-do list to make Anywhere searches also search tags (even if you don’t type “tag:TagName”).
With EagleFiler 1.4, tags are automatically included when you do an Anywhere search.
Thanks!
