Simple drop pad question (indicator of success?)
I dragged-and-dropped some text onto the Drop Pad and it imported just fine. But there didn’t seem to be any visual or audial indication of success, so I didn’t know it had worked for sure until I went in and confirmed the presence of the new record.
Is there a way of having the drop pad indicate a successful receipt of dragged-and-dropped info - just for extra reassurance?
doug
If you install Growl, it will show a little notification window (or play a sound) when EagleFiler finishes an import.
