Version 2.9.22 of SpamSieve is now available. This is a free update that includes the following changes:
- Works with Apple Mail under Mac OS X 10.11.1. It’s easiest if you update to SpamSieve 2.9.22 before updating to 10.11.1. In any case, if you don’t see the SpamSieve commands in Apple Mail’s Message
menu, be sure to choose Install Apple Mail Plug-In from the SpamSieve menu. Otherwise, with the SpamSieve plug-in not installed, Mail will move good messages to the spam mailbox without consulting SpamSieve. - If SpamSieve detects that training a message didn’t work because of an AppleScript bug in Mac OS X 10.11, it will now direct you to the new Duplicate Apple Mail Accounts section of the manual for a workaround.
- When filtering incoming messages, Apple Mail will now wait longer for SpamSieve to launch in case the system delayed respawning the launch agent. Thus, spam messages are more likely to be filtered rather than left in the inbox.
- If the launch agent is set to be continuously running, it no longer quits itself when Mail quits or SpamSieve quits/crashes. This should help ensure that Mail is able to relaunch SpamSieve right away, without Mac OS X 10.11 throttling the launch agent.
- The Apple Mail - Discard Spam script now has an option to set the retry delay to work around a problem with spam messages being left in the trash if Mail failed to delete them.
[LIST] - Checking the Apple Mail Setup
- Checking the Outlook Setup
- Faster Apple Mail Training
- Why do good messages move to the wrong inbox when trained in Apple Mail?
[/LIST]
SpamSieve 2.9.22 works with Mac OS X 10.6 through 10.11 and requires an e-mail client. Older versions are available for older operating systems. For information about previous releases of SpamSieve, please see the version history.
