SpamSieve update 2.9.6 up date crashing Postbox.
When select junk mail and hit the junk button it freezes Postbox.
Can I go back to the last version? That did work.
Postbox freeze.
I can manually move junk selected to the junk folder. So it’s got to do with the button.
Please choose Tools > Add-ons in Postbox. Which version of the SpamSieve plug-in does it say that you have? Also, please follow the instructions on the Sending in a “Sample” Report page.
Add on
1.0.4 Plug in
That’s actually the plug-in from SpamSieve 2.9.5 (the old version). I think you’re running into a bug in Mac OS X. The fix is to install the 1.0.5 plug-in from SpamSieve 2.9.6.
It’s fixed it.
Thank you for the fix!
