SpamSieve 3.3.2 is a free update for those who have already purchased the SpamSieve 3.0 upgrade. Normally, SpamSieve will automatically offer to update you to the new version. There are also instructions for updating on this page. SpamSieve 3.3.2 is compatible with macOS 10.13 (High Sierra) through macOS 27 (Golden Gate) and is recommended for all customers using those versions of macOS. Older versions are also available for macOS 10.12 (Sierra) and earlier.
Microsoft has again changed its plans for the Mac version of Outlook:
- Legacy Outlook had been scheduled to stop working on November 1, 2026. Microsoft now says that Legacy Outlook will continue to be available until October 2029. Some customers will no longer be able to connect to Exchange accounts starting in October 2026, but IMAP and POP accounts should continue to work.
- Microsoft is reversing many years of public statements and no longer plans to bring AppleScript support to New Outlook. As a result, SpamSieve’s current direct integration with Outlook will end when Legacy Outlook is no longer available at the end of 2029. We hope that another method of integration will become possible before then.
For more information about this and about how you can continue filtering your mail with SpamSieve, please see the End of Support for Legacy Outlook section.
When you move a message to the TrainSpam mailbox, after training the message SpamSieve now moves it to whichever custom location for trained spam messages you’d set (instead of always using Junk).
Checkbox values, such as for the Locked and Enabled columns, are now included when copying from rules windows.
Help links once again open in the system help viewer on recent versions of macOS.
Improved the following sections of the manual:
Restored the Help menu icons on macOS 27.
Improved the functionality of the app after the trial period has expired:
- SpamSieve will automatically clean up its launch agent file to simplify uninstallation if you choose to delete the app.
- The About SpamSieve, Software Update…, and Save Diagnostic Report… menu commands are now available.
- The help and Quit commands were previously available as buttons. These can now be accessed via the menu bar, too.
Improved the error reporting when moving spam messages in Apple Mail.
Tried to work around a seeming Xcode change that caused crashes when reading the corpus database.
Tried to work around a bug where Apple Mail failed to move Gmail messages out of a training mailbox.
Tried to work around a bug in macOS 27 where the Dock icon wasn’t hidden.
Fixed a regression where an error would be shown when launching Mail or Outlook if you had just deleted the SpamSieve app file (but had not yet logged in again).
Fixed a bug where replacing an old diagnostic report with a new one didn’t work.
Fixed a type-safety bug with software update.
Fixed a crash that could occur after software update.
