Hi, I am an Imac user with OSX Version 10.8.2 installed and Using Outlook Version 14.2.5.
I have downloaded and installed SpamSieve to try before I buy, I have attempted to setup as described in the manual, I have the rules setup exactly as described.
My problem is the menus, The screenshot 1 is all I can get and I cannot find any reference to “Whitelist” or “Blacklist” anywhere.
Screenshot 2 is my menu in the Main Bar, Again No reference to either, Also I could not find the “Install Scrpits” menu item and copy and pasted them to relevant folder.
Can anyone tell me what my problem is please as I really want this to work
What you are referring to as the “Main Bar” is the Dock. If you click on SpamSieve’s icon in the Dock (just once), you will see all of SpamSieve’s menus in the menu bar the top of the screen (next to the Apple menu): SpamSieve, File, Edit, Filter, Window, Help.
You will also see SpamSieve in the menu bar if you double-click its icon in the Finder.
