Michael,
Getting the warning window (quit & show instructions) every time i start Mail.
On 2 machines running BS b5
Reverting to b3 fixes that.
Michael,
Michael, I am also getting the warning window running BS b5 abd SS b4. I went ahead and deleted the DataVauls, etc., with the same result.
If you are having trouble getting SpamSieve to work on Big Sur, please contact me via e-mail and include screenshots and a diagnostic report.
There seems to be a bug in SpamSieve 2.9.40b4 where it will reinstall the plug-in at each launch. If you click Continue you should be able enable the plug-in in Mail and have it load. You will know it has loaded because youāll see the SpamSieve menu commands in Mail.
Iāve got the beta but get incompatible plug in from Mail Version 13.0 (3645.0.6.2.4). SpamSieve is at 2.9.4.b5.
Please try holding down the Option key when you install the plug-in, as this will tell SpamSieve to reset a Mail cache that could cause that error.
Does not work. This worked when I first used it. I ran Catalina and just rebooted to Big Sur and the hassle started.
Please save a diagnostic report right after you get the error.
Thereās a bunch of stuff screwed up that wasnāt before. Will wait to start fresh with the next version.
Cheers,
ā Harald
Installed beta9 and all is well.
SpamSieve 2.9.40 has shipped with support for macOS 11.
A post was split to a new topic: Incompatible
SpamSieve 2.9.40 appears to be incompatible with macOS 11.1
The SpamSieve 2.9.41b1 beta for macOS 11.1 is now available.
A post was split to a new topic: Apple Mail filtering not working on macOS 11.0.1
3 posts were split to a new topic: Apple Mail menu commands and hotkeys not working on macOS 11.1 Beta
macOS 11.5 Beta 4 is not compatible with SpamSieve 2.9.43, although Mail and SpamSieve donāt know this because the macOS beta erroneously declares the same compatibility UUID. I will post here when a new beta version of SpamSieve is available. Until that time, I recommend unchecking the SpamSieve rule in Mailās preferences if you are using the latest Big Sur beta.
SpamSieve 2.9.44b4 is now available with support for macOS 11.5 Beta 4.
SpamSieve 2.9.44 has been released, so a beta version is no longer necessary for compatibility with macOS 11.5 Beta 4.
