SpamSieve will move messages with much accuracy if I apply the rule manually. It is not doing it automatically when messages come in - except maybe 1 out of 20, for example.
It has always worked well for me. I recently bought a MacBook Pro - it is the one causing this problem.
I have already reinstalled the scripts - I have upgraded to 2.6.3 - I have one rule matching the instructions. “Spam Sieve - Move if Spam” - it is enabled. I ran the “Change Settings” script several times to make sure that it is ok.
(Mac OS X 10.4.10)
Go to Entourage’s Tools menu and select Junk E-mail Protection - DONE
Open the Mailing List Manager, also in the Tools menu, and see if there are any items listed there… - DONE
…and make sure that Synchronize contacts with Address Book and .Mac is checked… - DONE
Choose Install Entourage Scripts from the SpamSieve menu. DONE
Meaning that there are no mailing list manager rules?
The instructions don’t say to do that; they show it checked. If you uncheck it, Entourage will run your other rules on spam messages, so that spam messages that were caught get moved out of the Junk E-mail folder (if that’s what your other rules are set to do). Step 6 says:
If you have Entourage rules to filter your non-spam messages, or if you are using an IMAP, Hotmail, or Exchange account, you will need to do a few more things. Drag the SpamSieve rule to the top of the list and then follow the instructions in Two SpamSieve Rules.
