Strange bahaviour in Outlook 2011 for Mac
Hi.
I installed SpamSieve in Outlook 2011 like described in the manual. I checked the settings twice. But the behaviour is not normal. SpamSieve recognizes Spam mails, changes their colour but doesnt move them into the Spam mail folder. The stay in the Inbox folder. Why?
I have to move the Spam mails manually into the Spam folder.
In every case I’ve seen, this happened because the rules were not set up properly in Outlook. So please post or e-mail some screenshots so that I can check your setup.
Thanks for sending the screenshots. The problem seems to be that your “SpamSieve - Move Messages” rule says “If all conditions are met” where it should say “If any conditions are met”.
