Tag Cosmetics!
When tags are displayed at the bottom of the main display pane, they have a nice light blue circle around them – very easy to read and click on!
Would it be possible to use the same blue online/fill for “tag list” on the left-side library pane, and for the detailed file-list pane (when the “tag names” column is activated)?
It’s not only way more attractive than just plain floating text, but it’s easier to click on!
Thanks!
Joachim
I will consider that—thanks.
How is it easier to click on? You can currently click anywhere in the source list row to select the tag, so the target wouldn’t get any larger.
