I recently updated SpamSieve to version 2.6.2, and now my train as spam shorcut has disappeared. I’m using SpamSieve with Mail.app 2.1(752/752.2) on OS X 10.4.9. This is really hampering my email workflow since I’ve become so accustomed with using these shortcut commands. Anyone know of a fix?
Are you using MailTags? The current beta takes over the Command-Control-S keyboard shortcut. The developer says that this will be fixed in the final release. In the meantime, you could use the Keyboard pane of System Preferences to assign a different keyboard shortcut.
That would be the problem. I was wondering why the shortcut vanished all of a sudden. I think I updated the MailTags Beta right around the same time as SpamSieve, so I didn’t think MailTags was the problem. Thanks for the help, and I’ll make sure to keep an eye on the shortcut after MailTags updates.
This is fixed in MailTags 2.0.
