Is there are way of setting EagleFiler up so that it warns you before you delete? In a lot of applications, there is a facility that, if you go to delete an item, folder etc, asks you, ‘are you sure you want to delete this?’. It stops you accidentally deleting. Can this be set up in EagleFiler?
No, however (as in the Finder) records that you delete in EagleFiler are not really gone. You can undo, and the files remain in EagleFiler’s trash until you empty it. I think this is actually safer than warning you each time because after a while it becomes habit to click “OK” to dismiss the warning.
