web item dates
I don’t know if this is a bug, or a feature. I just pulled an image from the web directly from Omniweb into EagleFiler. I then went to ‘Recently Added’ to tag it, and noticed that its Date was February 13, 2003. Looking Finder, I see that’s the Date Modified, too. Is that the date it was modified on the server? Is this intentional, or does it not even fall under EF’s purview?
Didn’t necessarily strike me as buggy, though not necessary very helpful either.
It probably doesn’t have to do with EagleFiler. If you use the pop-up menu at the right of the records list (or simply Control-click on a column header), you can make it show the Date Added column, which might be more useful to you.
