Wondering about AppleScript submissions
I have adopted EagleFiler as my eventual (within the next 8 months) replacement for Evernote. It has everything I need, with much better Apple Mail integration and none of the frills like calendars.
One of my first “jobs” was to set up a capture and tracking system for my current position mentoring 20 people who work with about 700 clients. Their reports go into a remote portal that sends me a structured email for each report. I wanted to have each report sent from Mail to an EagleFiler library and extract tags for the visitor and client—visitors grouped together, clients alphabetized by last name.
I am familiar with programming concepts, but after 50 years of learning and abandoning different languages, not interested in learning AppleScript with all its deceptive quirks. I ended up using Claude Code to develop a pair of scripts (which still took close to 25 hours thanks to said quirks) to build the bridge I wanted. I insisted on heavy in-script documentation and explanations along the way, and the result is a pressure-tested production script, along with a second script for settings that are stored in a standard plist.
I don’t see anything recent in the list of AppleScripts available for EagleFiler (past about 2020). Is there any interest in some kind of script exchange library in 2026? Would AppleScript even be around once Rosetta 2 goes away completely?
I’m already entranced with what a well-thought-out solution EF represents. Scripting it for particular solutions makes it even better.
I’m adding new scripts (like Import From Paperless) to the official page of ones that I maintain. There’s also an older index of community contributions. That was created under the older forum software. You’re welcome to link to scripts there, but the forum now supports tags, so I think it makes sense to have a separate thread for each script (or family of scripts), and then you can just tag it with applescript and workflow (if you’re writing about how you combine EagleFiler with other apps) to make it easy to find. AppleScript is definitely sticking around post-Rosetta, and I think it’s going to see a renaissance because of AI (making it easier to write scripts and also demand for automated access into apps).
You can use the fenced Markdown syntax to get a scrolling box with syntax highlighting for AppleScript:
```applescript
Your code here
