Yep and Leap tags
I’m test driving EagleFiler and I believe I read that Yep and Leap tags would be identified in EagleFiler - I’m not seeing the tags in EagleFiler from either Yep or Leap. What can I do? Thanks.
Update…
Actually, tags generated in EagleFiler appear in Yep/Leap but tags generated in Yep/Leap do not appear in EagleFiler… Help!
EagleFiler will import any OpenMeta tags that are on the files when they’re imported into EagleFiler. Thereafter, the EagleFiler tags take precedence and are copied to OpenMeta unless you tell it otherwise. Please see this post.
