Add a folder as a type of record
So I have many draft folders of React projects that I look at for reference purposes. I don’t want to add each file in them, I just want the folder itself to be added to EagleFiler so I can write a note/tag as to what each one contains. Can this be added?
One way to do this is to create the empty folders in EagleFiler and assign the ef_unscanned tag to them. Then you can put other files/folders in them (using Finder) and EagleFiler will only show the top-level folder.
